Nasty Rattle at 1500rpms? (video)
Old 10-23-2006, 07:50 PM
FearLS1's Avatar
Default Nasty Rattle at 1500rpms? (video)
This just started tonite when I was head home. I could hear this metallic rattling bouncing off the houses. It is pretty loud at a low speed. I don't seem to have any performance loss and everything under the car seems to be tight. No loose exhaust shields. At 1500rpms the car runs a bit rougher than usual. Please help diagnose this!
Video
Old 10-23-2006, 07:52 PM
skifast87's Avatar
dude i would love to help but it brings me to the main page of street fire i cant see your vid
Old 10-23-2006, 07:53 PM
FearLS1's Avatar
taking them time I guess to screen it?
Old 10-23-2006, 08:37 PM
spazzyfry123's Avatar
Yeah, they are optomizing it right now.
I can say that I also have the same thing. I will have to wait for the video first to say if mine sounds the same, but I have a pretty nasty rattle from my exhaust somewhere near the headers at about the same place. Mine used to be only at about 1500 RPMs, but now it has developed to a range from idle (sometimes) to about 2200 or so. For a lack of better words, it really sounds like a bolt is inside my pipes somewhere rattling around. What does yours sound like? And where is it situated?
Old 10-23-2006, 09:32 PM
FearLS1's Avatar
It is located like exhaust/ cat area. That is exactly, like a bolt rattling around.
Kleeborp the Moderator™
MeentSS02's Avatar
Sounds like the exhaust rubbing against the heat shielding to me...
Old 10-23-2006, 09:58 PM
Asmodeus's Avatar
check your catalytic convertors for loose shields.
Old 10-23-2006, 10:15 PM
SS4Luck's Avatar
i have the same problem and i had a baffle let go in the cat and was rattling around
Old 10-23-2006, 10:25 PM
SSNISTR's Avatar
+1 to that. Or a loose or mis-alined hanger.
Old 10-23-2006, 11:33 PM
like the view?'s Avatar
check your exhaust and the inside of your cats if you still have them
Old 10-23-2006, 11:46 PM
Magnet's Avatar
+2 for the heatshield rubbing or being loose...
Old 10-23-2006, 11:55 PM
LS1obsession's Avatar
I believe your passenger catalytic converter has gone to ****. That's exactly what mine sounded like when it went bad, at relatively the same RPMS. It could be something else, but it's more than likely the cat.
Old 10-24-2006, 01:17 AM
FearLS1's Avatar
Thanks for all of the help. I will pull the cats tomorrow and check em.
Old 10-24-2006, 01:29 AM
sidewayz28's Avatar
i had the worst rattling sounds ever and it was just a heat shield on my cat.. one of the welds came un done
Old 10-24-2006, 07:32 AM
bjamick's Avatar
im with this guy its your exaust, at that certain note its vibrating and its against some metal somewhere.
Old 10-24-2006, 02:53 PM
Tainted's Avatar
i got the same problem, and one of the ahngers in the back is fucked up from where sergant dumbass ran into me
Old 10-24-2006, 03:37 PM
SSChevyManiac's Avatar
Sometimes the honeycomb inside the cat breaks up and rattles like marbles in a tin can. HEY! That's just what your's sounds like.
Old 10-25-2006, 10:55 PM
Yeah, mine sounds like that, but more of a high-pitched "PING"ing kind of sound. I think it's your cats. No idea what it is on my car though. Anyone have any thoughts of what it could be?
Old 10-26-2006, 10:44 AM
PunkerPontiac's Avatar
sounds like your cat conv. guts are loose in the casing. I had the same problem with mine.
Old 10-26-2006, 11:25 PM
FearLS1's Avatar
If I gut my cats, will it throw a code?
Quick Reply: Nasty Rattle at 1500rpms? (video)
