Lt1 Trans Am.. How Do You Change Fogs
hi i have a 97 lt1 trans am and i was curious how to reach the fog light bulbs.. I tried getting under it and its covered by panels. I dont feel like ripping panels off and then going to buy plugs. Is there an easier way? i know its NOT like the lt1 camaros..
There is a flap underneath the front bumper with 3 plastic rivet things, after you take that off there are 2 bolts holding the lamp into it's holder along with the torx screw just above the lamp from the front (T15 I think). After that the lamp should come out the front and you can unplug the bulb
one of mine is out, i can just switch the bulbs i take it and not the entire light assembly? are the halogens worth it? i seen regular bulbs for $7 and the halogens for $20
