Abs Harness location?
Rear: Driver side floorboard, facing the rear end. It's a body connector where the rear ABS channel(s) plugs in. Note: The fuel pump has a separate connector, but plugs into the same body connector.
Front: Driver side engine compartment, to the right of the power steering pump (standing in front of the car). There are 4-5 brake lines connected to the top of the ABS module. In front is the the ABS connector plugged in.
