replaced new opti now no start
Okay I just replaced with a brand new opti, and now it does not start, so I checked and the coil wire is sparking, and I pulled a wire off the sparkplug and it getting a really nice spark. So I assume it is not the new opti then. But I have had the cars front jacked up all day, and so I checked a plug and it is really wet. So is that my problem? And from what leaving the cars front up on jacks?
thanks
thanks
uhm, those teeth have to be lined up in the same spots they were when they were taken off. Otherwise the car will never start. Try turning the opti then putting it back on until it works. It sounds like it's not firing correctly.
oh forgot to mention it is the dowl type opti like here
http://shbox.com/1/opti_back.jpg
So it only goes in one way, so i dunno
Yeah, I was thinking gear opti. I dunno. Did you double check it when you put it back on? Did it have this trouble before replacing the opti and last of all, do you have your wires going to the right plugs. I messed that up once with 2 cylc on a v6 and it was really hard to start it.
yah all the plugs and everything are correct. I even pulled a sparkplug and it is sparking really good. So the coil is sending a spark to the opti. So there is spark, and i know there is fuel. But like I said the plugs a pretty wet so maybe they got flooded. how i dunno maybe from sitting on a angle on the ramps.
