guys help fuse keeps blowing out
Old 02-05-2007, 09:09 PM
MiaSSmaro98's Avatar
Default guys help fuse keeps blowing out
hey guys ive had my car for almost two years and since 4 days ago my cabin light/locks fuse keeps blowing out,wont even last 10 seconds.what can this be cant if use the remote for keyless entry have to open the doors with the key
Old 02-07-2007, 10:55 AM
Super Speed's Avatar
Put a bigger fuse in
Old 02-07-2007, 06:14 PM
doesnt always work,i found out it was my trunk light making ground becuase it came off the bracket
Old 02-08-2007, 07:54 AM
camaroguy26's Avatar
like MiaSSmaro98 says you've got it shorting out somewhere, the easiest to check would be the dome light but shoot all the wires to make sure they're not going to ground, if you find one is find where and fix or replace it.
Old 02-08-2007, 08:06 AM
davidz28guy's Avatar
i have the exact same problem, sometimes a fuse will last a week sometimes it wont last 10 seconds, its been broken so long im used to it now
Old 02-08-2007, 04:20 PM
Mohammed's Avatar
hell NO !! the fuse blows becase a high current pass through it ,,and you don't want that current to pass through your electrical equipment !!
NEVER USE A HIGHER CURRENT RANGE FUSE !!
