Need 98 Camaro tail light wiring diagram
Old 02-07-2007, 12:18 PM
LS1DER's Avatar
Default Need 98 Camaro tail light wiring diagram
I'm needing a wiring diagram of the external light system, specifically the tail lights, for a 98 camaro. I'm putting the lt1 lights on using the lt1 harness. I think I've got my problem figured out but my wiring diagram doesn't match what is actually there. Any help with a diagram would be greatly appreciated. Thanks.
Old 02-08-2007, 12:23 PM
01WS6/tamu's Avatar
Just match the colors of the wires they are all the same. No need to change the harness though if you are just changing the lenses they are the same harness from 93-02
Old 02-08-2007, 05:37 PM
LS1DER's Avatar
Well I traded the lights and the harness too, because I was told that I could use the 93-96 harness. It has only 4 wires. The 97+ has 5 wires. He has to have the 97+ harness for his to work. Problem is I need it too. I've hooked it up a couple of different ways getting closer to it working everytime. I've got another idea on how to get it to work. I'm trying it tomorrow morning. My wiring diagram doesn't match the wires colors that I have. I was just wondering if anyone had one. I'll figure it out either way. Worse comes to worse, I'll just have to buy the 97+ harness.
Old 02-09-2007, 04:52 PM
LS1DER's Avatar
Got it fixed. Thanks again whitebird00
Quick Reply: Need 98 Camaro tail light wiring diagram
