Cracked interior door panel...:( *DON'T QUOTE PICS!
Old 01-05-2007, 07:56 AM
  #201
after dark's Avatar
Originally Posted by JasonWW
I can.
Why's that?
Old 01-05-2007, 09:17 AM
  #202
JasonWW's Avatar
If you read this thread you will clearly see that the dealer can make several cases for not replacing them. Anything from user damage, to not being a wearable part, etc...
You should read the thread about the roof panels. The dealers can say and do numerous things to get out of repairs. A lot of it depends on the dealer and how you approach them.
Old 01-16-2007, 04:23 PM
  #203
77jimmy's Avatar
Does anyone have the part numbers for the panels?
Old 01-16-2007, 08:00 PM
  #204
'02 WS6's Avatar
29k on mine w/ inch long crack on pass. side.........and still growing
Old 01-16-2007, 09:18 PM
  #205
JasonWW's Avatar
You'll need your VIN to make sure you get the right color. Basically I think there's tan, charcoal and black and Monsoon or no Monsoon.
Old 01-19-2007, 12:00 AM
  #206
Camaro Ryder KV's Avatar
should have gotten a camaro
Old 01-19-2007, 09:03 AM
  #207
77jimmy's Avatar
Okay mine is tan with monsoon so does anyone have the part number. Even the panel assembly number would be a good start.
Thanks
Old 01-19-2007, 09:07 AM
  #208
JasonWW's Avatar
If you call the dealer they are going to ask for the VIN.
(Just in case anyone wanted to know)
Old 02-10-2007, 12:16 AM
  #209
litle88's Avatar
I had my car for 4 weeks, bought it with only 14,000 miles. Now I got a crack all the way down too on the drivers side. WTF Is anyone pursuing this further. I'm all in. Where do I sign. email zekevelazquez@yahoo.com 708-870-5500
Old 02-12-2007, 05:00 PM
  #210
angrychicken's Avatar
both sides are cracked here... SUX!
Old 02-13-2007, 06:30 PM
  #211
BANDITCAR's Avatar
I'm glad I fixed mine before the crack got bad on the driver and even appeared on the pass. side. the fix has been holding for 1 1/2 years now.
Old 02-16-2007, 01:35 PM
  #212
knight rider WS6's Avatar
Do I gotta buy a new door pannel or what? is there anything that can fix the crack? Just asking. the dealer wants like over $500.00 for that.
Old 02-20-2007, 05:53 AM
  #213
drain89's Avatar
mine too. 02 ws6. pass side. 29965 miles
pisses me off!
Old 02-20-2007, 09:16 AM
  #214
bjamick's Avatar
Ya i noticed mine yesterday is getting longer now its prob bout 2" long
Ya us Pontiac guys got by Pontiac they are all prob laughing while they read this thread..
Old 02-20-2007, 04:56 PM
  #215
BANDITCAR's Avatar
If the crack is not too long...like ALL the way down the panel. Its possible you can fix it. You just have to be good at applying the interior paint to the stressed area of the crack once it is back together to make it blend into the rest of the panel.
Old 02-23-2007, 10:42 PM
  #216
slvrta2002's Avatar
i just did the repair today that BANDITCAR's posted (on page 8 of this thread) and it seemed to work. we will see if it holds up. I did it to the cracked side and the side that wasn't cracked to see if it helps it from not happening.
Old 02-26-2007, 07:43 AM
  #217
SkLdBYAGrrl01TA's Avatar
I've got the same schtuff (cracks on both panels), and it has nothing to do with weather (I live in Florida). My drivers side is pretty bad and my passenger side is a white hairline (I purchased it like that with plans to buy new panels). I know absolutely nothing about these engines, but I do know the difference in sound between the way my doors close and the way my boyfriends do on his 01 Z28. (Maybe that's why their doors are covered in leather?) I think it's a flaw in the something inside that causes stress on the panel because mine sound very rough when they close.
Old 03-06-2007, 03:57 PM
  #218
Rybo Flavin's Avatar
After reading these last few posts, it seems that people haven't read Bandit's post back on page 8. I am confident that he posts the EXACT cause of this problem, so rather than trying to reinvent the wheel, everyone should make sure to read his post. To reiterate a previous post that I made...
Per Bandit's instructions, I took my panels off and found that although both the inside and outside of my panels were discolored in the "soon-to-be" crack location, the crack had not started to form yet. When I removed the staples, as Bandit suggested, you could feel the pressure releasing from the plastic and the discoloration on the back of the panel decreased significantly. In fact, after removing the staples from the passenger side there was almost 3mm offset between the holes in the seal and holes in the panel. Over time, I am sure that the 3mm of pressure would have grown until the panels cracking point.
Rather than using copper wire to replace the staples, I took a slightly different approach. I carefully used a drill bit to open the staple holes slightly larger than they were. Then I used very small cable zip ties to go through the holes and come together beneath the door panel. I tightened them enough to hold the seal in place, but not so much that it doesn't allow enough flex for temperature change. They worked perfectly and I am so glad that I caught this before they cracked.
Old 03-06-2007, 06:31 PM
  #219
BANDITCAR's Avatar
Thanks for the back up Rybo and good on you for altering the remount method to better suit your needs.
One of the reasons why I used the copper wire was because I had it handy and it was the first "fix" I thought to use.
Old 03-29-2007, 11:30 PM
  #220
leadfoot&aws6's Avatar
This happened on both my doors. The crack was so clean, all I did was remove the panel and use Locktite epoxy on the underside, clamo it together and wait. Came out great. If you'd never seen them before, you'd never notice them now.
Quick Reply: Cracked interior door panel...:( *DON'T QUOTE PICS!
