Could a bad alternator do this?
Old 06-29-2007, 04:36 PM
Michael02hawk's Avatar
Default Could a bad alternator do this?
As of yesterday, the TA will intermittently lose all electrical power.
As i'm driving along, I'll hear the radar detector reset, the radio cut-out for a second, time resets to 1:00, all dash lights light up as if the car was just started - all while I'm cruising along. The engine does not stall, and everything keeps running normally.
Could it be the alternator?
Old 06-29-2007, 11:57 PM
ultraz's Avatar
could be a few things... WHen i encountered those symptoms, my PCM went bad a little bit later and did not want to start. I had to replace the pcm and get it reflashed.
Old 06-30-2007, 12:29 AM
Da Swami's Avatar
If the voltage is dropping, you can bet it's your alternator. Same things happened to my car when the alt. went.
But if your voltage is fine, then it's something weird.....
You might want to check the two leads coming off the alternator just as a precaution.
Old 06-30-2007, 07:16 AM
Thanks guys...The voltage is solid , no dips or spikes. Just a brief loss off all electrical power. I didnt think it would be the PCM, but I'll keep that in mind.
Last night I went under the hood, removed all grounds, sanded the connections as well as the mounting surface where they bolts down to the frame. I also removed the battery terminals and made sure they were both in straight and tight.
Its a tough one, becuase I have to drive the car around for 20-30 mins to see if the glitch happens again or not.
Old 07-01-2007, 02:40 AM
staringback05's Avatar
most likely a bad ground or power wire crossed.....it will cause shorts like that
Old 07-01-2007, 07:35 AM
I found the problem. A few positive o-ring terminals coming together at the pass side fuse box area, at the factory + post, the nut wasnt as tight as it should be. Those wires got hot & started to melt away!
I've replaced all that, hopefully that'll fix the interior power problem!
Old 07-01-2007, 03:10 PM
bingo....
i melted a starter wire to a header and it did the same thing....just more catostrophic
