ses light from air lid I just order my MTI intake lid and the sensor hole wasnt drilled. i left it off and it through an SES light im kinda pissed about it. so what do you think send it back. drill the hole. can i just leave it off and turn the code off whats up? were these things supposed to be pre drilled? here are pics of what im talking about http://i2.photobucket.com/albums/y9/.../IMAGE_017.jpg http://i2.photobucket.com/albums/y9/.../IMAGE_018.jpg sorry this pic was takin with my cell phone. but you can see the blue end plug in that doesn have a home anymore :( |
Drill the hole and put it in, you have to have that IAT sensor in there. Plus you're missing a clamp from the Lid to MAF part. Peace, Craig. |
ya i put the clamp on. i was just putting it on first to see if it lined up. any trick to taking the sensor out. or putting the hole in a certian spot on the lid? |
Pry out the grommet out of your stock lid, might need a little spit to slide it off without tearing it. Then get a step drill bit: https://s7.sears.com/is/image/Sears/...Jf2Puqa4knlNp1 ....like that and put the bit up to the stock lid to get the size you need, then drill away on your MTI lid. Drill above the seem a good ways, like where the IAT went on the stock lid. :thumb: Peace, Craig. |
thanks craig. |
k got it drilled and got it in. it took a little while for the SES light to go away but its gone now and everything lines up great. |
No problem boss, glad to hear everything is cool now. :thumb: Next time you can just clear the code by disconnecting the battery and pull the PCM fuse in the engine bay for about 1 minute then put everything back and fire it up. The PCM will have to re-learn for a few minutes and will act stupid, but everything is fine. Peace, Craig. |
© 2024 MH Sub I, LLC dba Internet Brands
