Ideas on my power loss For the last few weeks my 99 Z28 W/6mt has been feeling a little sluggish. The car drives normal, not a noticable hesitation or anything but the power is not there. The car is stock except for a lid and exhaust. Im thinking maybe clogged cats, or fuel pressure. Where should I start? Thanks, |
the first two things that come to mind are your fuel filter and o2 sensors. replace before anything if it were me, i'd do the plugs and wires while i was at it. if that doesnt do it then you may have stuffed cats, but i'm leaning pretty heavily on the filter and sensors. |
Originally Posted by brucelee Im thinking maybe clogged cats, or fuel pressure. fuel filter plugs Has the car gotten a tuneup recently? |
plugs and wires should only have about 20k on them. Also I have no check engine lights on. fuel filter has been done but I might have gotten some bad gas. I filled up at wawa a few times before someone warned me of them having shitty gas. |
i'll say fuel filter, i had the same problem |
don't over look you o2s!!! they're really simple to replace and they can seriously slow your ride down - or worse... |
Yeah fuel filter, also make sure you didnt suck up something into the airfilter housing. |
I would have to agree with what you've been told about Wawa gas, there are so many additives in it that it is shit gas. I was commuting from Wilmington, DE to Atlantic City for 5 months and was initially using Wawa gas because it's cheaper than almost anywhere, but saw a difference of up to an 1/8 a tank or more difference per tank everytime I filled up with a better company. That could be the problem but if it's that noticable, i would check your plug's gap. If it was an o2, I'd figure a light would be on. |
i think im having the same problem! |
© 2024 MH Sub I, LLC dba Internet Brands
