oil drain plug
oil drain plug
just got a oil change and the oil drain plug was leaking a little, so i got under there to tighten it and the plug only tighten so much then turned loose again, now its leaking bad and it won't tighten is it just the plug (easy fix) or the threads in the oil pan are bad and i might need a oil pan, this happen right before work so i'll have to do when i get off.
It's likely the threads on the plug bolt itself. I had this happen on a truck - I just went down the street to autozone and picked up a fram oil drain plug - the kind with the goofy llittle hose so you don't have to remove the plug. I'd stick with the dealer plug though for the long term.
