What to use and how do you set the idle set screw?
Old 12-06-2007, 04:39 PM
CJDZ24_Z28's Avatar
Default What to use and how do you set the idle set screw?
I just got the code for low TPS voltage on my 00 Formula. The car is reading reading low. I tried my smallest socket and it doesn't fit on the underside of the TB. Thanks
Old 12-10-2007, 02:00 AM
jmdale1984's Avatar
I believe that your idle screw is gonna be a small torx screw.
Old 12-10-2007, 02:20 AM
kyles2000z's Avatar
yep, its easier to adjust if you take the TB off, unscrew the screw, and put it in through the top.
Old 02-06-2008, 05:00 PM
The_Wretched's Avatar
u got a picture of the idle screw?
Old 02-06-2008, 06:13 PM
newton's Avatar
My idle screw is orange I think. It's right near the bump stop...I think.
Old 02-06-2008, 11:29 PM
BigDaddyBry's Avatar
Yes.
I used a gear wrench fitted with an adapter that held the torx bit.
