View Poll Results: what oil should i use...
german castrol
19
34.55%
mobile 1
25
45.45%
royal purple
7
12.73%
amsoil
4
7.27%
Voters: 55. You may not vote on this poll
what oil and filters to get...
Old 02-29-2008, 02:42 PM
TX_SS's Avatar
6qts of dino oil valvoline 10w-40 with longer version of acdelco/wix/napa gold/microguard filter
Old 03-02-2008, 02:38 PM
LS1Formula98's Avatar
I have over 110K on my 98 Formula. I use regular (Not synthetic) 10w40 Castrol. When I bouht it back in 2000 thats hat they guy used, so that what I stayed with, and i have had no problems whatsoever. Up until 5 years ago, I was using fram filter, but started to read about the fram filters and as a precautionary measure just switched to K&N. A little more pricey (like a few bucks) but love the bolt as an added feature for removing the filter. So basically what I am saying is to stick with whats working, If it aint broke........
Old 03-02-2008, 10:25 PM
ReFtheMC's Avatar
Mobil 1 with Mobil 1 filter here
Old 03-05-2008, 12:07 PM
Mr Incredible's Avatar
I don't use any of those oils.
Just use plain old 10w-30 Pennzoil in the yellow bottle and change at 3k miles and all will be well.
Purolator filters are equally as sufficient.
Buying those expensive oils is just a waste for daily drivers and non-extreme racers....Mostly so you can sound like you know what you're doing.
Old 03-05-2008, 02:39 PM
streetassasin's Avatar
I just changed mine today: Castrol synthetic blend 10W-40 and a carquest filter, cost $30. It has 45psi hot idle with a LS6 pump
Old 03-05-2008, 08:40 PM
Luder[PAK9]'s Avatar
Doing my first oil change (since I've owned the car) this weekend. I took advantage of the sale at Autozone and picked up some German Castrol 0w-30 and a Mobil 1 filter.
Old 03-05-2008, 09:04 PM
mysupersportss's Avatar
I Use Mobil And Ac Delco Filters But I Work For Gm So.....
Old 03-08-2008, 12:28 AM
ckJoshZ28's Avatar
I go back and forth with redline and amsoil with a kn filter. Supposedly redline uses more basestock 5's than other synthetics and neither contain aggressive detergents like rp. Goes in clear comes out dirty; probally doesn't matter to much but peace of mind is worth 10 a quart I guess...Although I do go 4/5k now in between changes after seeing many private reports regarding sythetic break down.
Old 03-22-2008, 10:19 PM
kny3twalker's Avatar
mobil 1 extended performance, with mobil 1 filter
I change within a week or two of the light coming on, which is normally 8 to 9 months
not bad for < 40 dollars
Old 03-23-2008, 11:31 PM
ae13291's Avatar
i use mobil 1 5w30 with fram tough gaurd truck filter! the filter is pretty good, p.s NEVER buy those stupid high milage oil filters! they have a dumb plastic restricter that increased my oil pressure to more then 60psi normal driving! i replaced it as soon as i got home
Old 03-24-2008, 01:36 AM
ArrestMeRedZ's Avatar
I've used M1 for 25 years and never had a oil related problem. Last change, switched from M1 10-30 to GC 0-30. Reason: Base IV versus Base III stock. Very impressed. Filters: AC Delco, Supergard or Bosch for the most part. Cheap and good is my criteria. Switching to M1 truck filter next time (hey, they were on sale).
Old 03-25-2008, 10:24 AM
  #32
Z-RATED94's Avatar
Originally Posted by Mustang5.Ohater
Same here, RP and K&N.
Old 03-25-2008, 03:54 PM
  #33
Cherub's Avatar
I am running M1 w/ a wix truck filter. No complaints
Old 03-26-2008, 12:17 AM
  #34
633997's Avatar
I run amsoil 100% synthetic oil and amsoil filter on my LT1 w/ 185,000 miles on it and the car runs flawlessly.
