cruise control servo keeping throttle open
Old 03-17-2008, 09:40 PM
lmt0705's Avatar
Default cruise control servo keeping throttle open
im working on a 99 camaro with many issues, one of them is the servo that controls the throttle and the cruise control on the passanger side fender by the battery will not allow the throotle to close all the way. I tried adjusting the cables and it doesent help. do you have to reclock or reset the servo somehow?
lmt0705 is offline
Old 03-18-2008, 01:50 AM
ae13291's Avatar
is there something in the path of the throttle body blade like a tornado? lol i had the same prob, i took out that stupid tornado and problem solved
ae13291 is offline
Old 03-18-2008, 02:25 AM
lmt0705's Avatar
no, theres nothing in the way of it, with the throttle cable off it closes properly
lmt0705 is offline
Old 03-18-2008, 03:10 AM
ae13291's Avatar
well humm that is just weird! hopefully you get the problem solved it sounds dangerous
ae13291 is offline
Old 03-18-2008, 10:25 PM
lmt0705's Avatar
I learned something new today, there is a throttlebody from a 00-02 on a 99 f body right now and I noticed that the bracket that the cable loops around is almost 3/4 of an inch larger on the 00-02 throttle bodies then on the 98-99 ones. so swapping them out will do the trick.
lmt0705 is offline
Old 02-21-2024, 06:15 PM
Save the manuals!
wssix99's Avatar
If you don't have a scanner to look at the throttle position sensor and other sensors in real time, you can take this to any mechanic. The problem should be easy to find.
To hell with the dealer!
wssix99 is offline
Old 02-22-2024, 09:52 AM
bleepster's Avatar
I hope they solved this after 16 years - LOL
bleepster is offline
Old 02-23-2024, 09:39 AM
Save the manuals!
wssix99's Avatar
Thanks. lol. This came up on my feed for some reason and I didn't even check the date. We'll lock this one up!
wssix99 is offline
The following users liked this post:
bleepster (02-23-2024)
