View Poll Results: Have you tried Seafoam (in the tope end) on your LS1?
Yes, and my butt dyno gives it two thumbs up!
19
20.00%
Yes, enjoyed the smoked show, but no real change in performance
39
41.05%
Yes, and my LS1 exploded.
2
2.11%
No or WTF is Seafoam?
35
36.84%
Voters: 95. You may not vote on this poll
Have you Seafoamed?
Old 03-26-2008, 09:27 AM
Luder[PAK9]'s Avatar
Default Have you Seafoamed?
The Seafoam sticky (linky) only has posts from people that have tried Seafoam. I want to know what percentage of members actually try it.
Old 03-26-2008, 11:54 AM
xterminator's Avatar
ive tried it on several cars and its entertaining but ive never felt any difference except in my girlfriends 6 cylinder mustang it used to ping bad on regular gas and after i seafomed it the pinging quit
Old 03-26-2008, 02:21 PM
tennz28's Avatar
I did my 02 camaro with no real noticable results, but I did a freinds 89 dodge power ram and that thing runs 100 times better after seafoam. Im a sceptic when it comes to pretty much everything but im a fan of seafoam.
Old 03-26-2008, 02:25 PM
Shackleford's Avatar
I used it in the gas tank.
Old 03-26-2008, 03:07 PM
SladeX's Avatar
car feels the same, smoke show was cool.
Old 03-26-2008, 09:49 PM
ghardester's Avatar
I put it in the oil before an oil change and drive it for a day or so, not every change but a couple times a year. And at the same time in the gas tank. I haven't done the top end through the booster hose because my car only has 38,000 miles on it and I don't think it's needed yet. I'll do the full treatment at 50k.
Old 03-26-2008, 11:04 PM
Z28Fistergod's Avatar
I'd say it is more of a preventive maintenance type of procedure, if you wait 50k miles then you probably will feel a difference. If you regularly do the seafoam then you wont lose the power to begin with, therefore you wouldn't notice a gain when you did it.
Old 03-26-2008, 11:07 PM
z28berryhill's Avatar
well im at 90 k never tried and im doing it saturday i will let you all know...im doin the full treatment
Old 03-26-2008, 11:30 PM
Tech Resident
ChocoTaco369's Avatar
Of course I love Seafoam, but it's not much for a horsepower mod Only in the most extreme cases will you feel an increase in horsepower. Your motor has to be very dirty to the extent it's costing you a noticeable amount of power, and it has to be pretty dirty to do that.
However, just because you don't feel a power increase doesn't mean there are no noticeable differences. All the times I've done it, the emissions from the tailpipes are reduced and the car drives/idles much smoother. I've never noticed a power difference, but there is always a substantial difference in idle and drive quality. Seafoam gets two thumbs up from me
Old 03-27-2008, 01:57 AM
SOMcockySS's Avatar
my k5 smokes on cold starts and then goes away upon warming up. It also idles a little rougher sometime, but with 93 it seems to run fine. Maybe I should Seafoam?
Old 03-27-2008, 02:04 AM
Black99T\A's Avatar
I think im going to do mine just for the heck of it, the way I see it, it cant hurt anything. Ive changed my plugs and wires and my car but my car has always had little rough spot in the idle from time to time, not even hardly noticable most the time. I put some GM brand injector cleaner in it we had a work and I think it helped a little bit, but I think im going to try seafoam.
Old 03-27-2008, 02:14 AM
RooRnZ28's Avatar
never done it.... 80k on the clock. dont know if its good for oil lines/ turbo..? just wouldnt want to risk it.....
Old 03-27-2008, 06:03 AM
qwk93ta's Avatar
I'm thinking of doing it on my 96 Tahoe that has 111k on it.
Old 03-27-2008, 06:45 AM
96formulabird's Avatar
I've done it on my 96 LT1 in my formula bird. it worked i guess. but mine i did through the brake booster like it said and my car wouldnt stay running so i had to hold it at 2000rpm while my buddy poored it in. and when he poored the last little bit in i let off the throttle and it barely died. Then it dieseled(stay running after key is out and ignition is off). so i dont know what was up with that. but i had a little smoke i guess. my car had never had it done and it has 108,xxx miles on it.
Old 03-27-2008, 09:42 AM
PonyTamr's Avatar
Iv done it a few times to other cars, did it yesterday to the camaro, wasnt to much smoke, however the idle is NOTICABLY smoother, my friend when he got in asked if i did anything cus it was smoother idle
Old 03-27-2008, 10:30 AM
VA2001SS's Avatar
I did both my 01 SS and 96 454 Suburban, smoother idle but no noticeable power gain.
Old 03-27-2008, 12:26 PM
MasterV8's Avatar
Gave the car a colonic this weekend only smoked for less that a minute when my g/f got on it! but gonna do the volvo tonight with over 80k miles should be fun.
Old 03-27-2008, 01:38 PM
2_Huge146's Avatar
I haven't yet but I'm planning on it soon, 39,000 w/o a seafoam so I think it's about time.
Old 03-27-2008, 01:45 PM
5301113's Avatar
SEAFOAMed my car and it runs smoother. it more for maintances. U know air filter , fuel fiter, and spark plugs etc. It's a need to do job to clean the inside of the engine and the fuel system.It really works
Old 03-27-2008, 01:46 PM
Z Fury's Avatar
I plan on doing this before I put the headers/Y-pipe/Magnaflow on my car in a few weeks. For what its worth, the car has about 72K on it, and has never been seafoamed. I don't expect miracles, but I think it would be nice to have the internals all cleaned up before I do the installs.
I'm still "on the fence" about doing this on my truck though. At roughly 200K miles, and having never done the seafoam before, I think it may reveal some internal damage (I said "reveal" as opposed to "cause" because I don't think seafoam causes damage, but merely reveals the problems that are already there).
