Clutch pedal sticking?
Old 04-04-2008, 02:36 PM
jt76's Avatar
Default Clutch pedal sticking?
Is this a common problem? i have had it happen to me a few times already over the first 2 weeks of driving the car, last night being the most recent.
Old 04-04-2008, 02:37 PM
MonmouthCtyLS7's Avatar
Yea its a common problem thats why most upgrade to the ls6/7
Old 04-04-2008, 02:38 PM
LS1crazy01's Avatar
Very common. I suggest replacing the master and slave cylinder at the same time. Its also a good time to upgrade the clutch since the trans is out for the slave cylinder. Good luck!
Old 04-04-2008, 02:45 PM
jt76's Avatar
I have a new spec stage 3 clutch and a mcleod adj master cyl... both have less than 1k miles.... seems like the pedal itself sticks... wierd
Old 04-04-2008, 02:49 PM
LS1crazy01's Avatar
Did you replace your slave cylinder at that time? If not then thats your problem right there. I would suggest the Ram high flow slave cylinder and also do the drill mod. Make sure you take your time when you bleed it though or you will still have some trouble.
Old 04-04-2008, 03:03 PM
BadGTho's Avatar
i would actually start right now by bleeding it... keeping the fluid fresh, clean and free of air is key/
Old 04-04-2008, 11:43 PM
dcvingv6's Avatar
Here is a link to a sticky in the manual transmission section, its a pretty common thing
Sticking Clutch Pedal sticky
