need help cyl misfire and mean vibration
thought it was u joints only shutters under light load then if i give it allot it goes away until , my diablo programmer reads cyl misfire can this actually cause a huge vibration / shutter like this / it felt like it was in the rear but it was all inspected and no problems , tires good , my pinion angle is off from a bent torque arm mount but i was told its not that bad , please help i just got my new toy 2001 ls1 camaro with 40,000 on it how can i find which plug wir or coil pack is screwing up ? but i need to know has anyone had this vibration/ shutter from a plug wire or coil pack going or gone out as i have said under heavy load it blows by it thanks everyone the diablo reads code p0300 cyl misfire , how do i find out which one
same thing happened to my 97 but it shuttered all the time when i had it. at a stop light, light throttle heavy load. sounded like i had a mild cam in it but it was an ignition coil so i took it to the dealer to switch it out. does your temp gauge go up?
