| bamxbam | Jul 1, 2008 07:27 AM | Driver's Side Window Problem!!! Ok, I tried doing a search for "window switch", and all I found were threads in the nitrous section... just goes to show how much of a noob I am haha. But the problem is, in my 1999 z28, the driver's side window switch works on and off, it works sometimes, and most of the times it doesn't. When it does work, the motor seems to be fine, it goes up and down without hesitating (unless of course, the switch craps out). So how should I go about getting this fixed? Do you guys think it's just a bad connection somehwere, or is it indeed a bad motor? How much would it cost to get fixed?
*I originally posted this on "newbie tech", but just saw this forum and figured it was more appropriate. |
