99 corvette air condition leak
my dad wanted me to get on here and see if anyone knew the proper way for his 99 corvette to drain its air condition water. You would think it would drain outside of the car but there is water coming in on the passenger side floor board almost as if it was clogged up and its overflowing into the car. Anybody have any advise on this?
Thanks Trent
Thanks Trent
Pull the battery and the plastic battery heat shield out of the car and check the drain that comes out of the HVAC module. Make sure its not plugged. It should contact the cowl when properly installed.
my dads 99 has been going through the same problem.
at first his vent was blocked, but it still got a lot of condensation dripping onto the passenger floor. he ended up taking it in and they removed the hvac box and found it to be cracked. i dont know what they did to fix it, maybe jb weld, but its fixed now.
