General Maintenance questions
PW: library
Auto Repair->98->Pontiac->Firebird->Trans AM->Maintenance Intervals->Maintenance Intervals
* Clean airfilter
* New plugs (NGK TR-55 unless you're SC or spraying)
* Oil-change
Extended tuneup (in addition to the basic stuff):
* Transmission oil replace
* Replace fuel filter
* Plug wires
* Health-check on battery+alternator
* Inspect brake discs+pads, replace if necessary
* Power steering flush
If you haven't done it, I'd also recommend running a bottle of Seafoam in your gas-tank to clean out the injectors and fuel-system (do this before the fuel-filter change, as you need to change the fuel-filter after seafoaming)
* Clean airfilter
* Oil-change
* Plug wires
