Squeaking/grinding from the driver side rear ***HELP***VIDEO! My car is making a sqeaking/grinding noise in the rear. It's only towards the drivers side right where the wheel is. It can be heard pretty well from inside the car with windows up. It's also ONLY when i turn right. Pretty sure it's my suspension but I have no idea what as it has stock suspension with 120k miles on it. :bang: Couple days ago it started out as just a small squeak when I went over bumps or potholes. But now its escalated to a constant squeak and consistent with the speed of the tire. Hard to to describe...it almost sounds like something is grinding against the tire. Kinda sounds rubbery. HELP! I'll try and get a video here in a bit. thanks. EDIT: It also doesn't make a sound when I push on it from the rear... Here's the video: http://tinypic.com/player.php?v=5nn22r&s=4 |
© 2024 MH Sub I, LLC dba Internet Brands
