FAST 78mm or LS6 I'm lookin at buyin a new intake and was wondering the differences in the two. Also, would it be worth the money for the FAST overthe LS6. TIA |
With your current mods any aftermarket intake is going to be a waste of money. Get your motor breathing right first with a set of longtubes, get an ASP underdrive pulley, good lid, ported throttle body (I do them for $55 btw ;), and then at that point it'd be a good idea to upgrade to the LS6 intake. FAST intakes are more practical after you have internal mod work done. |
gefinite fast if u put a big cam in...i would do the fast 90 then...i got 42 rwhp from my ported fast 90 90 setup cause i got ms4 |
Originally Posted by Damian
(Post 10270544)
Originally Posted by 1bigcamdls6
(Post 10270573)
78mm would be waste of money.. do the ls6.... but if i were you id save up and get a ported 90/90.... i picked up 35rwhp.... ms4 cam. |
Originally Posted by lemons12
(Post 10270732)
Originally Posted by lookin4aTA
(Post 10270791)
I have read people say the 78mm is a waste, but not any reason why. as well, read my above post as to why the 90/90 is not really and option at the moment. I would love one, but it would be waste for me to do it until I get the cam. i would just go ahead and buy it and put it on when you can.. no reason to buy an ls6 if you plan on modding more later... if you have plans now, buy for those plans... just saying.. if you have to have more power now... and dont want to spend alot... nitrous |
(Post 10270842)
the reason it is a waste is becaus its not really that much better than an ls6 and its like 300 or so more bucks.... i would just go ahead and buy it and put it on when you can.. no reason to buy an ls6 if you plan on modding more later... if you have plans now, buy for those plans... just saying.. if you have to have more power now... and dont want to spend alot... nitrous |
If you want to get a FAST intake in the future leave your intake and throttle body stock for now. If a LS6 intake is good enough then do that with a stock ported throttle body. Its best to do one and not both. It will cost you more in the end. |
if i were you, id finish exhaust, beef up the clutch.. hell maybe buy some rims/tires.. pretty or drag.... and there is ALWAYS! suspension you could start on.. that doesnt need tuning.. or if nothing else just start buying parts for a cam swap.. intake, heads, cam, and all the little shit that adds up.. head bolts, gaskets, lifters, springs, timing chain, fuel pump.... goes on an on man.. |
Exhaust is first and for most right now. I'm on a 12 month plan right now and this is one of the major pieces to it. Intake will probably be after that, but I have been having problems with my 3-4 shifts the last few days, so I need to get the tranny figured out as well. If that isn't something serious that is a "cheap" fix, then an LS6 will be my next mod, and then suspension afterwards. We don't have a track out here, so wheels tires are really a big concern to me right now. |
(Post 10271497)
(Post 10271604)
syncros are going probably.. does it pop out of gear.. does it not let you shift into 3 and 4 gear under high rpms loads |
(Post 10271930)
Yes, it doesn't let me shift at high RPM loads. I've been suspecting synchros, but haven't been sure though. Wasn't sure if it might be that or maybe a shift fork. |
(Post 10271943)
syncros... might as well go to a built tranny.... |
(Post 10272190)
That is in the plan......and it is looking like sooner than later these days. once again though, somce down to finding someone who I can ship it to cheap cause I don't trust anyone on the islands. *it would be cheap... real cheap.. just let me know |
PM me the info and I'll let ya know. |
Theres just something not right about hearing "fix T-56" and "cheap" in the same sentence. Esp. if a $500 ebay FAST is pushin it. No offense, just observin. Shipping has to be killer to the islands. |
Originally Posted by SSickLS1
(Post 10273768)
© 2024 MH Sub I, LLC dba Internet Brands
