Need some Input 01 SS
Cleaned it up and went on and just thought i didn't get it back on all the way.Next thing that happens, when i take the lid off, is i see oil laying in front of the throttle body and in my smooth bellow, oil kind of smells gas-ey. Made me kind of leary, so i did a compression test, all cylinders were between 145-155psi except #7 which was 60psi....thinking maybe a valve wasn't seating...a couple days later the dipstick had popped out and the car started smoking again, so i pulled plugs out and #7 was pure black and smelled gas-ey. This is where i left off this past weekend, put a new set of plugs in, i do have a catch can, drove about 2 miles to get some gas, service engine soon light started blinking, which means a misfire, came back took plug out, plug was fouled out in about 4 miles. Switched a wire because it was not getting spark, fouled out another plug in 2 miles and car smoked the whole time, put new plug in, switched coil packs, plug didn't even last 2 miles and plug is fouled out again...what do you think the problem may be??
I'm thinking rings, any input would be greatly appreciated!
So my next question is, why are the cars notorious for doing it in general and esp. on #7?
What cause the ring(S) to go bad on these cars?
With this being said about the intake, what can i do about that before i put it back together, Port it, upgrade?
Thanks again!
Thanks, so what are some good heads out there? Need bigger injectors also correct? Want to shoot me a pm with some details and maybe some prices where i would be looking at minus the $1500 for the short block.
If I did a h/c/i car again I would do trick flows 215's, Vindicator cam, head studs, fast 90 or 92, and this will put you in the 470+. IMO
