LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   WS6 Ram Air Q's (https://ls1tech.com/forums/generation-iii-external-engine/1006659-ws6-ram-air-qs.html)
nitr0racing21 Oct 22, 2008 10:47 PM
WS6 Ram Air Q's
Is there a way it make it direct ram air and skip the loops and turns I can't find any info on this
Swaie Oct 22, 2008 10:53 PM
I know there is a way cause they acually have the filter mounted, with a gasket around the filter to seal it against the hood. I don't think you can do it with the factory hood though. I will see if I can find out where I seen that at though.
CoastieWS6 Oct 22, 2008 10:57 PM
Just pop the hood and you will see rivets ( wich hold the baffles in place). Get a drill with a small drill bit and drill out the rivets. After that put your and in there and pull out the baffles. The front baffles ( closest to the black grill )are a little harder to take out because they have glue on them. So just rock it back and forth untill it comes out.
DropTopBird Oct 22, 2008 11:28 PM
Search for debaffeling hood or sealing hood. Theres a whole bunch of stuff on it with a couple different systems.
nitr0racing21 Oct 22, 2008 11:42 PM
I found the Jaam Kit but I don't understand what it does can someone give me installed pics, not desinger pics but actually installed pics
And whats the difference between the 90$ one and the 195$ one?
Raise Oct 23, 2008 11:13 AM
You will be wasting your time bro. You will get much more air from a FTRA (or similar) setup. These cars are bottom breathers and naturally pick up their air from underneath from the air deflector. I have a WS6 too and I tried using the nostrils to route air in. Trust me, the best way is underneath. Seal the front of your airbox and open up the bottom. Ask around...I promise you you will hear the same thing.
PowerShift408 Oct 23, 2008 11:21 AM
Even Fast Toys says their FTRA is more effective than their JAAM kit on the website.
Fast Toys Performance Parts Oct 23, 2008 11:23 AM
We sell the JAAM kit. Basically it involvs removing the baffles from inside your hood scoop and then installing the seals included in the kit. The lower plate (the part that can be bought seperately), makes the lower nostrils in your hood functional as well. Once you close the hood, the seals meet with your air box and you have a true, sealed ram air hood.
Definitely get the complete kit for 195.00. The lower plate alone will not produce a ram air effect but some people like to buy it to make their engine bay look pretty :)
nitr0racing21 Oct 23, 2008 11:33 AM
So my question is what can I see more of a gain with in the long run the Jaam Kit or yours?
Fast Toys Performance Parts Oct 23, 2008 11:39 AM
Better throttle response, quicker ET's, more HP and better fuel economy.
We have only specifically tested the FTRA and it typically yields 2 tenths and 1-1.5 MPH in the quarter mile. People usually see 5-7 % increase in fuel economy and much better throttle response at highway speeds.
The JAAM kit will yield similiar results but probably a little less since it is pulling air from the hood which is not as efficient as a bottom breathing design on an fbody. People that have purchased the kit are still very happy with it :)
Adam2001WS6 Oct 23, 2008 01:57 PM
If you install the FTRA kit, do you lose the function of the nostrils/Ram Air hood set-up on the factory WS6 hood?
Fast Toys Performance Parts Oct 23, 2008 02:56 PM
Yes and No. They will not be blocked in any away but they will no longer supply cold air to the air box. Instead, they will just help cool the engine bay.
chrs1313 Oct 23, 2008 04:33 PM
let it breath from below...FTRA
jrpimp00 Oct 23, 2008 04:48 PM
+1 FTRA, ive had mine for well over 2 years on my 98 T/A and had one on my 98 RS. Just make sure you seal u the box good. This will give you better flow than the nostrils. And you dont have to tear apart your hood
© 2026 MH Sub I, LLC dba Internet Brands
