No code after !EGR
Old Dec 29, 2008 | 03:34 PM
00HAWK#068's Avatar
Default No code after !EGR
So I did my intake swap today so other than shreded forearms all went well.My question is how long till it throws a code? I just started it in the garage and let it warm up for a few and no SES. I really cant do a test drive the Hawk is in winter mode right now. I will have the codes deleted in the spring if needed, just was wondering if it takes awhile to throw one.
Thanks
Old Dec 29, 2008 | 04:30 PM
jetlag's Avatar
If you just let it warm up for a few minutes...that might not be long enough.
Some cars are different and codes will come on instantly or take awhile.
Old Dec 29, 2008 | 07:58 PM
jrpimp00's Avatar
It could take up to 50 miles before a code is thrown. It has to go through a complete drive cycle, I cant remember the exact time/mileage?
Old Dec 29, 2008 | 08:07 PM
Mike454SS's Avatar
EGR isn't active at idle...you'll need to be driving the car for it to try to use it and see that it fails the test.
Old Dec 29, 2008 | 08:58 PM
noriceinside's Avatar
just because the egr isnt actuated at idle doesnt mean it wont throw a code.
mine did as soon as i turned on the key and thats what they should all do. theres a position sensor internal to the valve and that circuit is now open and should therefore set a code.
Old Dec 29, 2008 | 09:04 PM
Mike454SS's Avatar
different years and different PCM's (as well as different flashes from year to year in the same PCM) react differently
Also, in a 2000 flash (what was in my car stock and should also be in his 2000 hawk):
P0400 "EGR Flow Malfunction" "No error reported"
P0401 "EGR Flow Insufficient" "MIL on first error" (this requires driving)
P0402 "EGR Flow Excessive Detected" "No error Reported"
P0404 "EGR Open Position Performance" "MIL on second error" (OP only started the car once, not twice)
P0405 "EGR Position Sensor Circuit Low Voltage" "MIL on second error" (this is the code you're saying should be lit...it probably will be next time he starts the car)
So depending on which code, we're both right. Some of them require driving, some of them just require a couple startups to see electrical EGR problems.
Old Dec 29, 2008 | 10:16 PM
no kidding. no action on a P0400? nice.
Old Dec 29, 2008 | 10:30 PM
LS199's Avatar
Put my intake on , took a couple days for a code, but drives normal
Old Dec 30, 2008 | 03:39 PM
00HAWK#068's Avatar
Thanks guys , I'll just see what happens this spring when I can get out and drive it alittle.
Old Dec 30, 2008 | 08:33 PM
68birdls1's Avatar
And hey here is a lil fun fact to keep those arms from getting torn up by those tiny tabs that hold the weather stripping down. Just pop'em up either with a screw driver or gently pull up on the weatherstripping and it will keep'em from tearing you up
