how do I wire angel eye halos to the fog lights in my Z.
Well yesterday I recieved my halos headlights and noticed that the halos wiring harness had two identical red wires. I then looked at the wires running to the fog lites and they both looked black, couldn't really tell cause it was getting dark. My question is, is there any particular way to wire these to the fog lites or can I just put the two red wires from the halos to any of black wires from the fog lites any help would greatly appreeciated.
thanks 1sicss
thanks 1sicss
Get yourself a test light and unplug the foglights and figure out what wire is + and - . Then splice into it. I would say that would be the easiest way. As long as the halos dont draw too much a pop the fuse. That I am not sure about.
Any particular reason your using the fogs? Mine are wired into the front running lights that way you can have them on with just front runners and the its optional if you want the fogs on with them or not. Just curious if your interested in doing it that way I can go see which wires you need to hook into.
