MAF connector Guys, I am looking for what connector to purchase from Casper's for the 5 wire MAF. For the time being, I will have a connector to plug the factory connector to (the 3 and 2 wire plugs) but I would like to remove that and just have one connector. I found this: http://www.casperselectronics.com/st...roducts_id=937 but I am not sure if this is right for the 5 wire MAF. I am having trouble with getting in contact with Casper's about this. Also looking for the tool to properly fix those small pieces on the wire. |
Found it: Connector: 413015 (1) Terminals: 504008 (5) Tool: 103001 (1) |
Are you trying to install an 85MM and use the built in IAT sensor but not have to splice the factory harness? If so, you want this part: http://fasttoys.net/shop/product_inf...oducts_id=1620 Thanks! |
No, I want to cut the wires and put the correct plug on there. All those plugs look messy. |
© 2024 MH Sub I, LLC dba Internet Brands
