Can i use a truck alternator?
I have a 00 ws.6 and my voltage regulator is takin a crap and my lights are flickering real bad ive already checked the ground straps and all that and they are fine. I just wanna know if i could use a truck alternator cause it puts out like 120 v as to the f body 105 or somethin.
The distance between mounting points on the F-Body and on the Truck alternators are the same, so will it mount; Yes. The only thing is, the case of the truck alternator (i have a 145 amp here that i replaced with a F-Body 200 amp for clearance reasons) is a good bit larger. It will fit in the bracket, but as far as clearing everything else down there IDK. Hope that helps.
my car has an alt from a mid 90's chevy pickup in it. has for about 2 years now with no problem
alt died in some small town while i was driving to panama city. ran a couple blocks to a napa to see if they had one and of course they didnt. we were going to do some street racing of there so we had a couple cars with us, one had a jack and a small tool set so i ripped the alt out in a gravel parking lot at 9pm and was able to match it up with some truck alt. worked great so far
I dunno there are 2 different types of truck alternators according to autozone and ive heard that a truck one works but i dont know which one and i cant find any threads that cover this
if you use the 120 amp from a 02 Tahoe 5,3 you will have no problems. I'll use it on a 5,7 ls Camaro.. the rear bracket will not work on the truck altr.
03 and up truck altr has a wire more in use. Stay with 01-02mod.
