LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Valve Cover Choice's?? (https://ls1tech.com/forums/generation-iii-external-engine/1074298-valve-cover-choices.html)
HUNTER02SS Mar 1, 2009 03:28 PM
What valve covers is everybody using to clear the shaft mount rocker arm's.
I have ETP 265cc head's and looking for some cover's to clear the jesel assy.
Jontall Mar 2, 2009 03:48 AM
http://www.nastyperformance.com/Valvecovers.html
vsocks1 Mar 2, 2009 07:42 AM
Which Jesels are you using and where did you get them? I am looking for some Jesels for my Z06. I went with Katech valve covers and coil relocation kit for my setup!
HUNTER02SS Mar 2, 2009 02:40 PM
Not sure what the part# is. They are the ones for the offset rocker's though? My engine builder and ETP talked and got them the correct part# for it.
vsocks1 Mar 2, 2009 03:20 PM
Do you know if they the Sportsman Series or the Pro Series?
Bad Blue WS6 Mar 2, 2009 03:27 PM
another vote for the Nasty Performance ones,,Nates a great guy to deal with:chug:
pmbmax Mar 2, 2009 03:50 PM
Those are the ones we could not get to clear yella terra adjustable. They where hitting the nut on the rocker, the guy brought them in so i am not sure what part number he used .( from other stuff related to build it was the cheapest they offer) Just firgure the room you need and ask befor you order. The covers look nice the welds where good but they would not clear.
DrX Mar 2, 2009 08:52 PM
Was this on ETP heads? Looks like they make a separate cover for them.
"Need extra room to fit those big roller rockers? Or make that Mod motor finally look like a performance motor? Add a set of these extremely great looking valve covers to top off that high HP motor. We have valve cover to fit all the different LS1-LS2-LS6-LS7-4.8-5.3-6.0L Corvette, GTO, F-Body, Car, Truck whatever motor you have. Even custom to fit NEW ETPerformance heads. Custom made to order"
ss_girl Mar 2, 2009 08:54 PM
I'm runnnig speed inc valve covers on my etp 225's.
Soul TKR Mar 2, 2009 08:59 PM
ABEAR had some of the nicest ones I've ever seen... but not sure what happened to them...
Katech also makes a nice set...
DrX Mar 2, 2009 10:03 PM
Katech can only say that their covers "should" fit.
I have some stock 5.3 heads here and the top rail on them is 8mm wide. On my ETPs it is 6mm wide. The ETPs are also 3mm wider between the rails. So things might not line up quite the same.
There is an online article where some stock valve covers were modified to fit on some ETPs because they supposedly sealed better than aftermarket. But even if I took the baffles, etc. out of mine, I would still have to cut out the tops of the covers to clear the rockers.
© 2026 MH Sub I, LLC dba Internet Brands
