Lpp header virbration
Old Mar 25, 2009 | 09:41 PM
97ta383's Avatar
Default Lpp header virbration
I have a real bad vibration on the driver side header i notched the k member and its not as bad but it still vibrates bad when idleing, when i put it in reverse, brakeing, or when i hit the gas hard it looks like it is laying on the motor mount not were it bolts to the motor but were it is connected to the k member has anyone had this problem cause it is very annoying and i cant figure out were it is coming from or how to fix it if i cant figure it out i may sell them and get arh i havent heard of anyone having problems with those put i really dont want to do that any suggestions
Old Mar 25, 2009 | 09:56 PM
98RedBird's Avatar
Put either poly or solid mounts in it.
Old Mar 25, 2009 | 10:00 PM
kdick91's Avatar
I heard poly motor-mounts help a ton, but I also heard installing poly motor-mounts makes pulling your own teeth look easy. From personal experience I can say before you buy anything, re-tighten and re-check everything! Your y-pipe can work itself loose at several places, so really get at that. If it's not all welded, take it by a shop and have everything welded up. But both of those options are cheaper and easier than the motor mounts or tubular k-member. And it's all healthy stuff. Hope that helped.
Old Mar 25, 2009 | 10:09 PM
bigti99a's Avatar
there are others who have had the lpps hit their motor mounts. search it and see what people did. changing the mount will not fix this issue. if the y pipe is banging the floor that stronger mounts will help.
Old Mar 25, 2009 | 10:21 PM
TORCHD 02 TA's Avatar
Sounds like for one you need poly motor mounts. and it seems like the LTs are resting on the k member.. Notch the k member and the vibration will go away
Old Mar 25, 2009 | 10:22 PM
97ta383's Avatar
i was thinking of trying solid motor mounts cause i dont think its my y pipe because i can feel the vibration near the peddles. would i be able to put them on without taking my headers off?
Old Mar 25, 2009 | 10:23 PM
97ta383's Avatar
I notched the k member with a punch and it wasnt as bad but i can still feel it
Old Mar 25, 2009 | 10:28 PM
I would not recommend SOLID motor mounts, you will hate them. And the vibration is the LTs resting on the k member. I know you said you notched, but is it resting somewhere else? Steering knuckle?
Old Mar 25, 2009 | 11:35 PM
97ta383's Avatar
No ive looked over it a million times and i can see it resting on the motor mount thats why i wanted solid mounts cause it looks like they have more clearence and i dont think the poly mounts will help cause it will still be resting on the motor mount
Old Mar 25, 2009 | 11:43 PM
well like i said, you will hate solid motor mounts. You think the vibration that you are experiencing now is bad. Put in the soild mounts.....
Old Mar 26, 2009 | 08:57 AM
CayenneRedV6's Avatar
I had the same problem with mine. What I did was take it off dimple the primary that was making contact with the mount AND when I re-installed it I adjusted it better than I did the first time. Most of the vibrating was because of bad installation. I also unbolted the Y-pipe from the floor and took off the metal/rubber thing, that was also causing vibration. My y doesnt hit the floor at all. Like I said it's in the adjustment. I have lots of clearance between the mount and the primary now.
Old Mar 26, 2009 | 04:06 PM
97ta383's Avatar
Yea that sounds like a good idea its just taking it back off thanks for the advice im going to have to play with it and see what i can do. how did you dimple the primary?
Old Mar 26, 2009 | 05:01 PM
98RedBird's Avatar
Wrong. Changing the motor mounts to solids will solve the headers hitting the mounts. The solids have much, much more clearance.
And you will not hate solid mounts...
I don't understand why everyone always is so scared of solid mounts. They are not NEARLY as bad as what people make them out to be. Hell I had a solid mount car with an MS4/PRC head combo and it didn't bother me in the slightest. No problems at all. I took three friends of mine, all separately for a ride after the solid mounts and not one of them could tell that I swapped mounts...
Really, they're not bad.
It will solve all of your problems. If it is also hitting the K member then you'll need to notch it but other than that solid mounts are definitely the way to go.
Old Mar 26, 2009 | 05:05 PM
Heat it up and hit it with a hammer. Just mark it while its on so you make sure and do it in the right place.
Old Mar 26, 2009 | 07:28 PM
DeadOnWS6's Avatar
i have lpp's on my 2000 ws6 and they fit great. i did get a vibration like you're speaking of though. It ended up being my y-pipe. Easy fix.
Old Mar 26, 2009 | 10:26 PM
97ta383's Avatar
How did you fix the y pipe vibration?
Old Mar 26, 2009 | 11:15 PM
zacht's Avatar
im in the middle of putting LPP's on my car, so far the fitment is great, but when i test fit the driver's side header i see it hitting the K-member already, before i get too into it im going to knotch a good 1/4 to 3/8 out of it. plus the poly motor mounts should help. id say those are a tick shy of being solid. and about the comment of makes pulling your teeth look easy, you weren't kidding. that could be the hardest most time consuming thing i've ever done.
Old Mar 27, 2009 | 12:19 AM
RevGTO's Avatar
Pontiacerator
I have the XS headers which is what the previous design LPP's were called. On the driver's side, we had to notch out the K-member, dimple the primary to get it away from the motor mount, elongate the holes on the mounting flange, cut the collector off and reposition it to keep the Y-pipe from hitting the body brace ... so welcome to the party.
Old Mar 27, 2009 | 04:28 PM
7plagues's Avatar
sucks
Old Mar 27, 2009 | 06:22 PM
Grn4fbody's Avatar
My LPP's hit my mount when I mocked them up on the K-memeber out of the car, so I did some custom fab work on my mount, I shouldnt have a problem
