SLP lid rubbing SS hood
I read a couple threads but everyone just says either haha mine doesnt rub, or haha buy this one it doesnt rub...
Anyone find a fix to get the lids not to rub.
Problem I am having is the top center section of the lid is rubbing the hood scoop as it comes around under the hood.
Keep in mind I have a SLP lid, cut to fit smooth bellows from SLP, NW 90 TB, and a n20 plate... space is kinda limited to get everything to fit haha.
Is there anything you can trim on the lower intake area or on the lid itself to get it to sit down a little bit? Im guessing the bellows is what is causing my issues... Thanks
Some rub and some don't, after trying several things I finally just stuck a piece of of dark gray foam on the spoy wher it rubs. It stopped it from scratching the hood and doesn't look too bad.
