LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Going to do LT's, need a tap and specs please! (https://ls1tech.com/forums/generation-iii-external-engine/113555-going-do-lts-need-tap-specs-please.html)
v8maro Nov 11, 2003 10:42 AM
Ok, when I put my manifold back on my car after the H/C swap one of the bolt holes got cross-threaded. I need to re-tap the hole in the head for the header bolt again, and clean out another one, what size tap do I need and what pitch ect? Where can I get one for a descent price?
thanks
-Steve
2001SS#3013 Nov 11, 2003 11:39 AM
TTT need to know also.
2xLS1 Nov 11, 2003 11:47 AM
M8x1.25
v8maro Nov 11, 2003 11:58 AM
Know where I can get one? How hard is this to do?
thanks
v8maro Nov 11, 2003 01:34 PM
Ok, i found this page http://www.discount-tools.com/rfn-100ms.cfm and they have it for $13.77 (sorry if it's not a sponsor, none seemed to have one) Now, I want to use a hand tape right? How do i know if this is going to fit between the head and the engine bay?
thanks
v8maro Nov 12, 2003 07:43 AM
To Teh Top
Cal Nov 12, 2003 11:05 AM
You should be able to find one locally, that will save some time. If the autoparts shops don't have one, try an industrial supply or machine tool supply (lathe & mill.) It's going to cramped in there; the standard T-handle used on taps might not work. You can use visegrips, but be careful; use plenty of cutting oil and reverse direction frequently to break the chips. Yes, use a right-hand tap.
© 2026 MH Sub I, LLC dba Internet Brands
