LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   What's the latest take on knife-edging the TB blade? (https://ls1tech.com/forums/generation-iii-external-engine/1155081-whats-latest-take-knife-edging-tb-blade.html)
Intercooler2 Jul 28, 2009 07:41 PM
I was looking at the new 95mm and was thinking about knife-edging the leading edge. Good idea or no?
redtail2426 Jul 28, 2009 07:57 PM
waste of time on a 95mm throttle body.You might gain .000001 hp,if your lucky
Intercooler2 Jul 28, 2009 08:00 PM
The guy I worked with offered to do it for me so it is a free .000000001 HP so I figured why not.
redtail2426 Jul 28, 2009 08:16 PM
well if thats the case why not
SweetS10V8 Jul 28, 2009 09:31 PM
Because it can ruin the TB altogether. YOu dont want to mess with the blade. If it accidentally doesnt get done perfect youl have idle issues because the blade wont be able to seal the throttle bore like its designed.
NOT WORTH IT....
Intercooler2 Jul 29, 2009 05:23 AM
Yea that the reason you only touch the leading edge not the back sealing edge. My TB also doesn't have the common bleed hole and I was debating about adding that.
vsocks1 Jul 29, 2009 05:32 AM
Don't do it!
Intercooler2 Jul 29, 2009 08:55 AM
Both?
chrs1313 Jul 30, 2009 07:00 AM
dont knive edge it, not worth the risk...only have a tuner drill a hole for the bleed hole if it is necessary...
MelScrilla Jul 30, 2009 11:22 AM
i wouldnt mess with the blade for the little difference it may or may not make in performance. It doesnt seem like its worth it.
01ssreda4 Jul 30, 2009 11:34 AM
i agree.....:)
© 2026 MH Sub I, LLC dba Internet Brands
