Easy to change O2 Sensors?
My O2 sensors seem to not last very long. So instead of paying a shop to do it i would like to switch them out myself. Is it an easy process, even with adding the extensions?
well if you have had them changed recently maybe pretty simple otherwise........No it is pretty simple they just may need heated up to get them to break loose do to the constant heating and cooling
I had a helluva time getting my 02's out of the stock exhaust, but they eventually broke free. Took some serious muscle! And ya....you might want to consider finding the problem instead of just replacing them...
Well since i have had my cam swap they have been going bad pretty fast like a year and a half at the most. Its been tuned a million times so i dont think its running rich but my car is low and i try to avoid driving it in the rain for that reason.
Which O2 replacements do yall recommend and extensions?
Most of the time outside things causes them to go bad. If they hang down and are upside down they will fail. They should be vertical if possible and shielded from outside sources WATTER DIRT ETC. Remember the O2 sensors uses outside air to work properly. Hope this Helps Tom
yeah im with some people on the tune, then again, if its been tuned idk what to say.
also, arent rear C5 O2's about the best O2 out there? i have long tubes and soon to get rid of the rear O2's (no cats) and change my front O2's. I was thinking about the corvette ones, i think they have longer wires and no need for extensions. someone correct me if im wrong, on both, if they're better, or if they have longer wires.
No codes are being thrown. But when im driving and let off the gas my car starts to buck a little. Its not as bad as it has been in the past with bad O2's and i want to fix it before it does get that bad.
