What pulley puller did you guys use to pull your ASP?
This will be the first time I have had to do and I know I cant use the 3 prong puller that I used to get the stocker off. I have heard you need to use a
"crows foot" puller which threads right into the holes on the ASP. Is this the standard harmonic balancer puller I see in all the auto stores? Or is there some special kind or some sort of special bolt that I need to get it to work?
The posts above are correct. I didn't have real good luck finding the correct size puller when I purchased mine a few years ago. I ended up having to take the Dremel out and lengthening the screw slots in order to get all three bolts to thread into the pulley.
Exactly- the nice Lisle 45500 tool is just a bit too small, I'm finding. And I have to use bolts from something else, as that kit doesn't have the right ones... what a pain.
