O2 Sensors and 110 / race gas
This may or may not be a dumb question but need some answers. My LS1 is built, pump gas, 500+ flywheel hp motor, and am wondering if there is any advantage to putting 110 octane in it, or will that gas possibly melt down my o2 sensors due to more heat overall everywhere? Will this also affect the ecu tune done to it as well? Is there any power/performance to be gained by doing this? Appreciate any feedback possible, thanks.
If its built to run on pump gas than it wont gain anything just by dumping 110 in it except kill the cats and probably the 02's.
In order to take advantage of the higher octane, you would need to add timing or more compression.
Not worth it.
Ive got 6 gallons of 112 left over from last racing season and if I knew it wouldnt kill the o2's and cats I wouldve already ran it through my car.
Not worth it.
Probably not, I was considering experimenting with it if it would yield any better results (not that I'm unhappy with it now). Like anyone else, just looking for gains anywhere I can at cheaper costs. Thanks for all of your guys' input so far.
as unbelieaveable as it might sound, right before i put LT's and TD's on my car, i ran it on 93, then dumped 5 gallons of 110 in it right before i made 3 more runs, and as the 110 got in the system, it picked up 3mph in the 1/4. this was basically stock car. i didnt care if it killed the cats or O2's because i was ditching the cats and getting new O2's.
for one reason, and its real world....
i had my dad's 402 BBC on the dyno at school, (the same place the jegs engine masters is held every year) and we tuned it and timed it to run on 93, then switched the fuel to 110 CAM2, changed nothing else, same 30* total timing, same jets same everything back to back dyno runs, and just the switch in fuel gave us 15 more HP average over 3 runs.
then we gave it 6* more timing and picked up another good bit of power...
i dont quite beleive this...
some fuels are more knock-resistant than others. thats why we have octane ratings. Octane rating does not relate to the energy content of the fuel (see heating value). It is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner.Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause autoignition.
It might seem odd that fuels with higher octane ratings are used in more powerful engines, since such fuels ignite less easily. However, an uncontrolled ignition is not desired in an internal combustion engine. The fuel must be fired at a precise time. An ignition too early will cause detonation.
A fuel with a higher octane rating can be run at a higher compression ratio without causing detonation. also more timing is aloud for its slow burning characteristics.
A common misconception is that power output or fuel mileage can be improved by burning higher octane fuel than a particular engine was designed for.
Since switching to a higher octane fuel does not add any more hydrocarbon content or oxygen, the engine cannot produce more power.
the engine and tune have to be set up for a specific octane to BEGIN with, simply switching octane levels effects nothing
Very possible... Or operator error, or you were knocking and need more octane from the begining.
You need to make about three runs, make sure they overlay well and then average them all together to get one set of data. Then swap parts and do three more runs. Throwing out any high or low flyers along the way, and theres a few runs in every session that just arent good data..
Best case senario, you reinstall the original part and rebaseline for the most accurate and beliveable results....
