UPS man left me something nice today
Well, my SLP LM exhaust came apart at the weld so I decided it was a good time to just upgrade to a true dual system. Then if I'm doing true duals, I might as well upgrade the headers and since I'm doing headers it'd be the best time to do motor mounts, so here goes.
Pacesetter LT's coated, Poly mounts, and TSP True Duals. I'll be installing them on Monday. I can't wait guys. Also I won't be able to get it tuned till the end of March, will it be ok to drive without the rear O2's until then or will it run really poorly or anything?
LS1Tech Premium Sponsor
You'll be fine without the rear O2's....they just monitor cat performance so you'll have a code set on the dash, but it'll have no affect on the A/F ratio.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Alright, awesome thanks. I wasn't sure if it'd lean out or something because the rear O2's but that's good. I'll try to take pics of my install. My friend and I are gonna be trying to tackle this next Monday. I'm hoping we can get it done in that full day. We're planning on starting really early and working until we get it done, but we'll see. As long as we can get the headers and mounts in then I can drive it home and finish up the exhaust the next day.
Well, 18 hours later my friend and I had the headers and mounts done, then I drove it home and mounted the exhaust in an hour. Then, was driving around enjoying the new exhaust and broke my rear driveshaft U Joint lol I had to remove the driveshaft loop for my duals and I've never messed with U joints before so I think I over torqued it. Going to get a new one today and fix it. Already pulled the driveshaft out and got the old joint out. I'm loving the exhaust and headers though. It sounds so nice and really wasn't as loud as I was expecting it. I'm thinking I may keep it as dumps for a while. I don't notice it too much. I'll try to take some pics soon
