LPP headers Hitting Motor Mount
I've got the passenger side in but the driver side is being a real bastard. The front pipe on the header is hitting the drivers motor mount. What do I do? Its also touching the k-member. I can't get the bolts to line up.
Thanks,
Nick
Thanks,
Nick
So maybe the spohn solid mounts mentioned in this thread would do the trick?
https://ls1tech.com/forums/generatio...nts-sphon.html
I had the same problem, I grinded away at the motor mount a little, then I put a jack under the collector end while tightening the header to the motor. Mine might still be resting on there but I dont notice it. I wouldnt worry about it, comes with the price of a cheaper header.
I just ordered the solid mounts from speed inc. I fought with it a little more today just to make sure it wouldn't fit. I'm not willing to grind or modify the headers. I figure I might as well take advantage of the situation.
Carl at LPP had this to say.
"We have had a couple of people that had the header hit the motor mount but it didn't keep the bolts from going in.
They just had to pull the header back a little with the bolts installed to get some clearance. You can enlarge the bolt holes a little more if you need to."
By the way taking the passenger header off that I already installed was a bitch!! Those damn stage 8 bolt clips suck even more to take off.
