Bolt pattern dimensions for FAST 90/92mm TB or other aftermarket TB
13 Second Truck Club
Do the FAST 90 or 92mm throttle bodies have the same bolt locations as a stock unit? Im talking about LS1/LS6 3 bolt manifolds and throttle body.
I did some measuring and calculations yesterday and a stock unit has enough material between the bolt locations to clear a 92 mm opening. Basically, other then the manifold opening being smaller than the TB opening, would a FAST/Edelbrock/Nick Williams aftermarket TB bolt to a stock manifold?
