Flowmaster collector vs. Magnaflow collector?
Going to customize my hooker y pipe. I'm using the pipe and just changing out the collector. The Hooker piece leave much to be desired in terms of a collector. I've seen the flowmaster collector but can only get it dual 3 in and a 4 inch out and would have to buy the reducer for it. The magnaflow collector is dual 3 in and single 3 out. Just haven't seen it used in many applications. Hoping the better collector will get rid of some rasp as I'm looking to remove the bullet muffler in the I pipe so I can rearrange my cutout so it doesn't sit so low and put a QTEC on it. Any info or advice on if it will even be worth switching the collectors is appreciated!
John
John
MM98,
Did you put the flowmaster collector on your Pacesetter Y pipe. If so I would really like to see it. The Hooker crap is the same as the Pacesetter collector. How hard was it to make it fit? Thanks.
How did you guys reduce the 3.5 down to the needed 3 inch?
Originally Posted by John02SS
MM98,
Hope this helps ya out.
Mike
Thanks guys!
MM98,
Shoot me an email and let me know how it turns out when your done. I'd really like to know how the rasp is with the better collector. Thanks bud!
John
MM98,
John
John, what kind of muffler are you running as of now??? The Hooker aerochamber will reduce alot of rasp & even more so with a good y-collector.. I used to have a single in/out 40 series Flowmaster w/ my Macs & ory, let me tell ya, the rasp that set-up made was horrible. Swithed over to just the Hooker muffler & new y-collector & now the rasp is pretty much eliminated.. I would highly suggest the use of the y-collector not only to help out on the rasp, but to also get better flow because of the smooth transition into the I pipe that it produces. Goodluck & I'll let ya now how the new set-up sounds..
Mike.
Mike.
