Help Rear main seal leak during install
Is it possible for the rear main to leak when installing an engine with just the weight of the oil on when tilted??
I am installing a used LS1 motor into am RX-7, I didn’t think twice to check if there was oil in it thinking the guy would have drained that before shipping it. Well I hoisted it up and then got her angled up on the load leveler and once I got it in the car I noticed oil coming from the bell housing behind the block. I pulled things back out and apart, also drained the oil as it was full, and it looks like the oil came from the rear main seal. It was clean on the back side of the block and I don’t see any sign of a previous leak so it just seems a little strange. Suppose I should replace the seal. Thanks for your help!
Was the flywheel bolted on? The crank is drilled straight through for the flywheel bolts. If you tip the motor with any of those bolts out oil will pour out.
If the flywheel was on you could also check the oil seal plug in the center of the crank. It's usually fine but it can get banged when replacing the pilot bearing.
