LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Full bolt on A4 in 11's? (https://ls1tech.com/forums/generation-iii-external-engine/1315435-full-bolt-a4-11s.html)
Average Joe Aug 7, 2010 02:59 PM
I'm curious what it will take to get a full weight a4 ls1 f-body to run in the 11.6 range without diving into internals. I have all bolt ons minus a fast intake, pulleys, and electric water pump. Any advice one can give is greatly appreciated, thanks!
jsteele90 Aug 7, 2010 03:02 PM
a well working suspension,sticky tiresm and a good stall. a track with good air helps too. the track i go too the da is never lower than 4000
Detoxx03 Aug 7, 2010 03:11 PM
11.6 might be pushing it but I think a 11.9 is feasible with the right suspension, sticky tires, good converter, and of course right track conditions.
86zcamaro Aug 7, 2010 03:25 PM
I ran a 14.1 at 101 six times last wed with my car being an 01 with ls6 intake, slp ram air, slp lid, bellow, 85 mm maf on 17 275 zr1's. There was a 05-06 ls2 gto running 14.2 at 98-99 so unless yours is one of the lucky ones to run really quick from the factory I doubt it honestly.
Im hoping for low 12's high 11's with dart pro heads, slp pully, full exhaust, cam, 3600 stall and a built trans. Want to get the 315 tires on the 11" rear zr1's.
Average Joe Aug 7, 2010 03:32 PM
A yank 3800 is being installed as we speak, that and adjustable lca's, but Im scared to grenade the rear with sticky mickeys. :laser:
jsteele90 Aug 7, 2010 03:35 PM
my rear has survived tons of abuse. they last longer in the auto's. my car went 12.2s with bolt ons at 4300 da. so 11s with bolt ons is very possible. that yank will really wake your car up. and 86zcamaro sounds like you and your friend need the driver mod bad those times are terrible
Average Joe Aug 7, 2010 03:40 PM
Well it sounds like with a few minor changes I should be well on my way to snake eyes, appreciate the info, and it sounds like we have a match starting... :engarde:
jsteele90 Aug 7, 2010 03:41 PM
match?
Average Joe Aug 7, 2010 03:43 PM
Just thought it humorous that you called out the dude above for horrible times lol.
jsteele90 Aug 7, 2010 03:46 PM
well it seems like hes butthurt cause his car runs 14s so he assumes everyone elses car must be slow since his is
Theblacknightls1 Aug 7, 2010 03:48 PM
Somthing wrong with your car or the track. My buddy ran a 13.56@ 106 Stock except for a lid fram filter..A4 z28 00
Average Joe Aug 7, 2010 03:49 PM
You said butthurt, and your in Oceanside, definitely a Marine huh?
jsteele90 Aug 7, 2010 03:50 PM
look at my avatar what do you think. !!!
garygnu Aug 7, 2010 03:54 PM
do you have a ls6 intake and a PnP TB?use lite weight rims and short tires.remove the spare tire and back seat.remove the front sway bar.get a adjustable torque arm and panhard bar.it only requires 380rw hp with the right combo.
Theblacknightls1 Aug 7, 2010 03:55 PM
It will be hard to break 11s but it can be done. I would at least cam it then your goal would be easier
Average Joe Aug 7, 2010 03:57 PM
Sorry bout that... :offtopic:
I thought so just never seen that unit insignia before.
Anyways thanks for the info, it's nice to know my rear is safe, no homo.
Theblacknightls1 Aug 7, 2010 04:00 PM
your rear safe?? What rear?? I know your not talking about a stock 10bolt being safe
Average Joe Aug 7, 2010 04:00 PM
What about this?
http://www.youtube.com/watch?v=362vK_gBeRE
Theblacknightls1 Aug 7, 2010 04:05 PM
Some people have done it before. Your car is not making any serious power so you might be able to get away with it. I snap my Driveshaft in half and broke my rearend lauching @ 2500 rpms with my stock gears on nittos 555r
Average Joe Aug 7, 2010 04:08 PM
Well...
Your T56 is the destroyer of rears and breaker of driveshafts, guess since my 10 bolt will last i should worry about my 4l60e huh?
© 2026 MH Sub I, LLC dba Internet Brands
