Spark Plug's time to change !! I tried a few searches here & there for a proper write up on how to CORRECTLY install spark plug's with PROPER GAPPING !! ... Got 8 NGK TR55 Spark Plug's, NOT TO MENTION THE STOCK 99 EXHAUST MANIFOLD'S =( Can somebody please help me understand how to gap my spark plug's ?? what are the tool's required for an easy day of work (not to spend 1/2 a day on 1 plug) .... i think a write up haven't yet been done in this forum, right ? Any USEFULL input is appreciated =) regards |
Should be all you need besides a 5/8 deep well socket and ratchet http://i237.photobucket.com/albums/f...d/DSC01666.jpg |
I also found a a few extensions helpful, I used a .75" and 3", IIRC. And #8 is WAY easier from underneath, unless you have arms like Popeye. I was able to do the plug AND wire from underneath. It was actually pretty easy, IIRC #6 was harder. |
take off the coil packs from the valve covers also, that helps too |
Originally Posted by King Nothing
(Post 13805439)
what are you gaping them to ? |
Originally Posted by StuntmanMike
(Post 13805531)
I started to do that, but the last bolt was such a PITA to get at I said the hell with it and left them on. It was easy enough to do with them on, the only thing is the heads of the bolts will dig into your arm a bit at times. |
After you remove the last bolt on the passenger side coil pack bracket thow the bolt away..you do not need it..unles you have a 1998 model..if so disreguard that thow it away statement...:D check out this link it may answer your questions. http://www.installuniversity.com/ins...g_and_wire.htm |
The last set of TR55s I got were actually really close to the stock recommended gap. I don't have too much trouble getting to the plugs even with the coil packs on (#8 actually isn't the worst for me, but then again, I'm short enough that I can put a knee on the battery and lean/lay into the engine bay), it's the god damned plug boots that drive me insane. My hands are too big to really fit down in there, so I'm always trying to figure out if the damned boots are seated right. |
(Post 13805531)
Originally Posted by WYATT318MOPAR
(Post 13805259)
Should be all you need besides a 5/8 deep well socket and ratchet http://i237.photobucket.com/albums/f...d/DSC01666.jpg So say you are gappign the plug to .060" do you want the .060" number to read on the middle of the plug, or to the left or right side of the plug? |
Originally Posted by TORCHD 02 TA
(Post 13813269)
Stupid question.. When you gap a plug, where do you want the plug to sit on the gapper? So say you are gappign the plug to .060" do you want the .060" number to read on the middle of the plug, or to the left or right side of the plug? I was going to draw an MS paint picture to illustrate my point, but you really don't want to see my horribly lacking MS paint skills. |
Originally Posted by Z Fury
(Post 13814020)
The tool gaps the plug wider as the plug moves around the gap tool. In the picture above, the plug is gapped to 0.040. If you measured at the middle, the gap would be slightly larger (the width of the spark plug comes into play here, as it rotates up the "ramp" of the tool). I was going to draw an MS paint picture to illustrate my point, but you really don't want to see my horribly lacking MS paint skills. So in that pic, you say that's at .040".. Now are you looking at the right side of the edge of the plug? That's how I see the .040" |
(Post 13814116)
Yeah I know that the gap gets bigger lol.. So in that pic, you say that's at .040".. Now are you looking at the right side of the edge of the plug? That's how I see the .040" |
I changed my plugs out a few thousand miles ago and I can't remember what I gapped them at. It was what everybody on the board suggests. I am gonna change them again when I do the LT's. Just wondering what the suggested gap size was. Car says .060, but thats too big of a gap according to the LS1 gurus. Can't believe I forgot what I gapped them at. lol |
^gap them at 55 and you should be good |
Originally Posted by djfury05
(Post 13814534)
yes sir, read on the right edge of the plug's prong :D |
(Post 13815017)
(Post 13814116)
now that is all the info required... getting my engine mounts in & the plugs right after ... thank you all |
| All times are GMT -5. The time now is 02:08 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
