LS1 shutting off like a Diesel
My 98 cam only ws6 is shutting off like a diesel truck..dont know why..maybe its in the tune or timing..was wondering if anyone else was having the same problem, or have heard of this before.
It's called "dieseling", it's caused by detonation after the motor is shut off..leaky injectors? Running lean, turning the spark plugs into a glow plug when you try to shut down? Do you get any knock or pre-det while it is running? Does it run hot or overheat?
You need fuel in order for an engine to run on, so the injectors must be leaking. Combined with hots spots of carbon on the pistons lighting up the fuel.
In the old days, this was a common problem because the fuel would keep on pumping and being sucked out of the carb. I had an old POS that used to run on, if it got hot enough, for about 30 seconds after I turned off the ignition. Funny as hell.
