Oxygen sensor placement behind cats
Here's what I'm dealing with:
My first instinct is to put the bung right behind the cat, where the pipe it still straight.... but is that too close to the cat?
And if I decide to put the sensor aft of the bend, how far after the elbow will I need to go so that I'm not getting a bad reading from the exhaust flow obstruction on the turn?
Appreciate any help here; I'm not used to setting up exhaust systems with cats
are there to do a monitoring job by decree. There is
no other use for them. You can put them in, but likely
no amount of "engineering" will make up for the fact
that they're gonna just be too cold to be reliable and
you'll still see the codes. So fix the codes.
time happy. But they won't be, or not for long. The
bigger, longer, higher-surface-area tube will not stay
hot enough. And just wait until winter.
