Kooks released new exhaust for f-body
Old 08-16-2014, 08:36 PM
  #961
SmokedOutZ28's Avatar
I plan to have not installed the system yet. There is a link a few pages back where someone made it work with there CME
Old 08-20-2014, 03:55 PM
  #962
MarylandSpeed's Avatar
Originally Posted by JakeFusion
Okay. Yeah, I'd rather do a cap than a plug. Most M18 plugs are for oil pans. I'm not sure they'd like the exhaust heat. I did see that Kooks sells the same SS plug that's in the header for the wideband O2, but they are $13 a pop. Blah.
We normally do not sell them separately, but you can add the caps when you order. Remember, call us for great deals on these @ 443-730-9428!
Old 09-10-2014, 03:23 PM
  #963
Just got a couple more of these in stock and ready to ship!
Old 09-10-2014, 04:02 PM
  #964
Super Hulk Smash
JakeFusion's Avatar
What an awesome system. Sounds good. Installed easy. And looks awesome.
Old 09-10-2014, 09:36 PM
  #965
mac62989's Avatar
^Couldnt have said it better myself Jake. Maryland Speed was also great to deal with for all the Kooks stuff Ive bought.
Old 09-25-2014, 03:20 PM
  #966
Thanks for the orders so far! We just got more of these in stock!
Old 11-13-2014, 01:45 PM
  #967
We have some great pre Black Friday deals going on these. Call us @ 443-730-9428!
Old 11-15-2014, 04:11 PM
  #968
OffspringZ28's Avatar
Do these fit around a Watt's Link?
Old 10-03-2015, 12:16 AM
  #969
X-ray's Avatar
Has anybody run Spohn solid motor mounts with this exhaust? I know they raise the engine up a little more than other options
Old 10-05-2015, 12:23 PM
  #970
bigz28man's Avatar
I'd like to know the same thing. Im looking to run the watts link from BMR and Im not sure if it will fit
Old 10-05-2015, 06:44 PM
  #971
LPE 403's Avatar
^^ it fits....guy with a TA had one on here for awhile.
Old 01-15-2016, 07:50 AM
  #972
Thanks for the info!
Old 01-24-2016, 09:43 AM
  #973
X-ray's Avatar
Well I went ahead with the Spohn solid motor mounts and Kooks true duals and I can now personally confirm that they work great together! Love those Spohn solids. That combined with a Lunati camshaft and the Kooks headers/exhaust turned it into a totally different car, in a very good way. Oh yeah, also got it lowered with BMR springs but everything fits well. Very tight, but it fits.
Old 01-28-2016, 02:21 PM
  #974
BrntWS6's Avatar
Well...I'd say it installs fairly easily initially. Took me a lot of tweaks to get it just just right so there were no leaks and nothing hitting though. Had to put the car back up on stands a few times and buy a few different parts to get it just right.
Old 01-29-2016, 08:18 PM
  #975
Super Hulk Smash
JakeFusion's Avatar
It installed easy for me. Took about 2 hours.... the hardest part was the rear hangers and getting it to sit up over the axle. Use an impact to tighten it. No leaks then.
Old 02-26-2016, 10:49 AM
  #976
zman02's Avatar
I've got these on my 02 z28 vert. tight fit. had to loose my tunnel brace and fuel tank shield. sounded awesome first month then my exhaust note changed slightly still sounds good. battled leaks with the coulplings so we lacked them to prevent movement. over axle was a tight spot for touching suspension.
Old 02-26-2016, 03:52 PM
  #977
kinglt-1's Avatar
I am thinking about switching the x pipe section out for the catted version. Since doing the H/C/I swap last spring the car is louder in spots of the rpm range. It is tolerable for me but it's a bit much for my 4yr old. Mainly around 45 mph there is a drone that was not there before. I have heard the kooks high flow cats flow good but I am guessing the price of that Catted X is going to cost as much as I paid for the Exhaust back in 2011. Any other ideas without hacking the exhaust up?
Old 02-26-2016, 10:33 PM
  #978
OVRKILL's Avatar
For ME, I gained 35hp peak and 20+ a cross the curve in gutting them thru my 460. I would assume less for small cubes, but still.....
Old 02-26-2016, 11:53 PM
  #979
kinglt-1's Avatar
yea pass on that...the exhaust is definitely tolerable and sounds excellent. not worth messing with if I am going to lose a bit of power...I thought maybe if it was 5whp or less, it might be worth it for less fuel smell and a little bit quieter.
Old 04-08-2016, 08:43 AM
  #980
Kooks True Duals for the Win!
Quick Reply: Kooks released new exhaust for f-body
