O2 extentions or Bosch 13111's?!?!?! Which should I do. What would you guys recommend. Will either throw codes. Which one is BEST. Using Pacesetter ceramic coated LT's. The reason I ask is bc I see mixed reviews on this question on here and looking for more up to date answers. Thanks!! |
i had extensions and i switched to 13111's when my o2's finally took a shit and so far everything works perfectly |
Originally Posted by King Nothing
(Post 14304422)
I say just use the 13111. Autozone will replace them up to one year if you have problems. I have not had problems with mine yet and have had them on for 3 months. |
Try the extensions first. They're much cheaper than new ones. Many people have had bad results with the Bosch's. I went 20k or so on the stockers with extensions before codes started getting thrown. Then I tried Densos and Bosch and had problems from the get-go. I've had the best luck with a set of used Corvette rears I bought on here. |
Originally Posted by RevGTO
(Post 14304939)
There is no solve to the problem man. I have been reading about these 02s for months now and still don't see the answer. I just go the best route and with a 1 year cover on the 13111s you can't go wrong. If you are already having code problems then you might have other problems. |
Originally Posted by justinj
(Post 14305979)
i have the Denso's and O2 extensions for about 2 years now. its been good so far |
I would tend to go more towards Denso or NGk than bosch. People still have issues with bosch sensors myself included. No matter which way you go you will still probably get the p1153 and p1133 codes for slow switching unless theyre switched off there really is no fix for these codes as the placement of the 02's are downstream in the longtubes however if they are turned off there really is no downside mine and most people are. Anyway the densos are OEM on new gm vehicles and for me they have worked better and switched faster than my bosches ever did I havent used NGK's personally but a lot of people like them. Dont bother with extensions unless your current o2's are brand new they probably need replacing after all o2's are really only supposed to go 75k-100k miles before they SHOULD be replaced. Extensions allow the chance for water intrusion around the connectors, i think its about an extra 40-50 bucks for new sensors so why not. |
Originally Posted by redbird555
(Post 14306219)
Yes just get the densos for the rear of a c5 corvette the part no i believe is 234-4617 |
I neglected to mention that I will be getting a DYNO Tune directly after all my bolt-on mods. Will this keep the front O2's from throwing codes or will it not make a bit of difference?? |
well you will throw codes simply because of the headers/cats and some other mods you may have however the tuner should be able to turn the codes off :D |
(Post 14308001)
Originally Posted by PheonixLS1
(Post 14305527)
Thats the thing though, I don't want to just throw money around hoping it will work. I want to spend my money on a SOLID solution instead of buying one thing then having to turn around and buy something different. I don't have that kinda money to play with. Thats why I'm here trying to get some solid feedback and results so my FIRST purchase will be the right one. As I said, I've had the best luck with factory O2's, whether my originals or the used Corvette ones. No luck with aftermarket. As someone mentioned, the exception is if your O2's are high mileage - above 80k or so. Then they're almost guaranteed to throw codes once you move them. The trouble is, Bosch's aren't likely to perform any better. |
(Post 14308320)
Whatever you do is no better than a roll of the dice. I'd rather throw $25 at the issue and hope that it works than $120-150. Extensions/Bosch/Denso all work for some guys but not others. Why not try the cheapest solution first? As I said, I've had the best luck with factory O2's, whether my originals or the used Corvette ones. No luck with aftermarket. As someone mentioned, the exception is if your O2's are high mileage - above 80k or so. Then they're almost guaranteed to throw codes once you move them. The trouble is, Bosch's aren't likely to perform any better. |
Do you have bungs on your pipes for the rear O2?s You'll get a SES if those are missing regardless of how the fronts are functioning. The real solution is to tune those DTC's out. Do you know somebody who can tune? You're going to want some tuning to maximize your LT's performance anyhow. BTW, I have a extra pair of extensions lying around. I'll ship 'em to you for $20 if you want to try 'em. Not a big investment and they just may work. PM me if interested. |
Bosch 13111's. They have a higher wattage heater and will work better with long tubes. Mine work perfectly and are very often reccomended here. Fifty bucks each on ebay. Worth it. |
Here's the definitive thread on Boschs. You'll learn quickly that results have been mixed. More info about them than you ever cared to know. https://ls1tech.com/forums/pcm-diagn...n-sensors.html |
| All times are GMT -5. The time now is 02:31 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
