Need help with driver's side kooks headers
Old Feb 9, 2004 | 06:00 PM
Kurt D's Avatar
Exclamation Need help with driver's side kooks headers
how do you get it in there? passenger side when in easy.
Old Feb 9, 2004 | 06:04 PM
Mike K.'s Avatar
These worked for my hookers so I am sure it will work for you. Take out oil diverter plate, two small 10mm? bolts right above the oil filter. Take out oil filter if you have not already. remove steering knuckle and make sure you have the car as high as possible so you can manueuver the header good. Good luck!!
Old Feb 9, 2004 | 06:27 PM
WILWAXU's Avatar
other handy tip.
turn the head flange straight up and down, and slide it in first.
Old Feb 9, 2004 | 06:30 PM
jd13's Avatar
Get the car up high.
Remove the steering linkage.
Remove oil filter.
I unbolted the motor mount and jacked the motor up about 2 inches.
After all of the above it went it so simply it was amazing.
Old Feb 9, 2004 | 07:55 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
You dont have to remove any of the steering assembly or jack the motor up. You have to have the oil filter off. The key is to get the car about 25 to 30 inches off the ground. You have to work the flange in then it will fit real close to the to the k member but then it will slide right in. You just have to wiggle it and fanagle it a little. Trust me it will go in with out removing those parts. I know because I just installed a set of kooks lt's and ory on my 2000 TA.
Old Feb 9, 2004 | 08:55 PM
ss rally red's Avatar
Just installed a set of Kooks this weekend(along with TSP231/237) both sides slid right in!
Old Feb 9, 2004 | 09:04 PM
Kurt D's Avatar
yep, turning the flange straight up, removing the filter and with a little prying on the tranny they finally slid in.
Thank you all.
Kurt
Old Feb 9, 2004 | 10:58 PM
Mike K.'s Avatar
cool glad you got it done. How do you like them?
