LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Dynomouth placement, what's the difference? (https://ls1tech.com/forums/generation-iii-external-engine/138476-dynomouth-placement-whats-difference.html)
nameisnana Feb 13, 2004 08:35 AM
Local muffler shop told me it was better to put a dynomax bullet in the same spot as the stock muffler, instead of the I-pipe.
I didn't have a reply to that.... I just know that everyone here recommends putting it in the I-pipe and fabricating a Y for the dual tips.
The same place quoted me $325 to do the job, so I know they're smoking something... but I wanted a little more info.
Also, is there a problem with leaving the stock driver side 'oval' or flat exhaust pipe (right after the cat) or should I have a round one fabricated?
Thanks.
Kev98Ta Feb 13, 2004 09:15 AM
That dosent make sense to me. How could they put a bullet in the stock mufflers place? Our mufflers use a single inlet and dual outlets. A bullet has a single inlet and outlet. Unless your only going for a single tip look from the bullet? Most people weld it into the I pipe w/ a y in the back w/ dual outlets. That makes sense.
That flat exhaust pipe you talk about is called a y-pipe. Youre probably best off leaving that alone for now, especially if ur ever gonna do headers. Or you could get an ory (off road y - no cats) for now. Plus they're cheap.
felton316 Feb 13, 2004 11:38 AM
I have my bullet muffler where the stock muffler was, but I had a 98 SS that came with a single exhaust tip. It cost me $30. They charged $10 a weld (welds X 2) plus $10 to cut the old muffler out. So $325 seems to be a ripoff.
© 2026 MH Sub I, LLC dba Internet Brands
