BBK LT's ready to install how high
Old Mar 3, 2011 | 09:14 AM
Z06 Steve's Avatar
Default BBK LT's ready to install how high
I wanna know if a set of rhino ramps will give my 2000 Z28 enough lift for the install? Do the BBK's both install from the bottom?
Old Mar 3, 2011 | 11:07 AM
SWEET98SS's Avatar
I did LPP long tubes, I had the car 16" high from the bottom of the side of the car to the floor. Im pretty sure they will install from the bottom. I also did my tranny at the same time so I had to have it this high to get the tranny out. I dont think ramps will be high enough.
94Z28-MSTGKLR's Avatar
I doubt it will be high enough and yes they will both install from under the car.
Old Mar 3, 2011 | 01:01 PM
99Bluz28's Avatar
If it's lowered NO, stock height maybe!Do you have some good jack stand that will take it a good 6" higher do that. Then jack up the rear of the car and put the ramps under the rear tires. That way it'll be easier to install the Y-pipe also.
